E39 airbag - cidlo sedacká spolujezdce jak nahradit?
CernyPetr
#21 Příspěvek od CernyPetr »
Neco noveho?
Dneska se mi to vystoupeni kamose taky rozzsvitilo :(
Patrik
#22 Příspěvek od Patrik »
Horis to poslal a uz me to nesviti ale byl to boj po tom ze to nepsalo chybu u spolujezdce si vzpomela roznetka pasu u ridice pomohl kontaktol a konecne me nesviti kontrolka airbagu.
Mimochodem Horis dik a doufam ze je tam hodnota takova jako ze tam nekdo sedi a ne ze pak dostane pytlem 8) :lol: :lol: :lol:
CernyPetr
#23 Příspěvek od CernyPetr »
Nemel bys tam Horisi jeste jeden kousek?
Predpokladam, ze se pak jeste musi na diagnostiku smazat chyba aby to zhaslo, nebo?
Patrik
#24 Příspěvek od Patrik »
ano presne tak diagnostika je pak nutna ja nevim co tam presne je je to ve folii ale vypada to ze tam jsou asi 2 odpory bohuzel jsem to nemeril takze vám moc nepomuzu ale se stekrem za ty prachy bych to ani neresil pro to jezdit do mesta a neco letovat.....ale kazdej je jinej
deafff
#25 Příspěvek od deafff »
BMW prave kvoli tomuto stiahlo do servisov 200tisic aut, nemusia zabrat predne airbagy...bohuzial teba sa ten recall asi netyka.
The German automaker says the recall involves the 2006 3 Series, the 2004-2006 5 Series, and the 2004-2006 X3 compact sport utility vehicle.
The National Highway Traffic Safety Administration said in a posting on its Web site Wednesday that small cracks could develop in a seat detection mat and lead to the front passenger air bags to be deactivated.
It would also turn on the passenger air bag "on-off" light. NHTSA (NIT'sa) says the head protection system would not be affected.
The company said last month there had been no injuries or accidents tied to the problem.
Description: BMW is recalling 200,000 model year 2006 3 series Sport Seat, model year 2004-2006 5 series Standard and Sport Seat, and X3 passenger vehicles. Depending on the manner and frequency of the front passenger's entry and exit, small cracks have developed in the mat. If this occurs, the front passenger air bags, with the exception of the head protection system, will be deactivated and the air bag warning lamp as well as the passenger air bag "on-off" lamp will be illuminated.
BMW is extending the warranty to 10 years from first registration without any mileage limit to the following vehicles: model year 2006 6-series, 3-series (standard seat), model year 2004-2005 Z4, model year 2004-2006 7-series, model year 2006 X5, and model year 2004-2006 5-series (comfort seat). Under the extended warranty program, the occupant detection mat in a vehicle that experiences this specific issue will be replaced at no charge to the customer.
"Solution: Dealers will rework the front passenger seat sensor mat so that external force application to the seat does not cause a crack to the mat. The recall is expected to begin during late September 2008. BMW will also extend the warranty on these vehicles to 10 years from first registration without any mileage limit.
mamouschek
#26 Příspěvek od mamouschek »
Dečka stojí kolem 2 litrů, ale dražší je tam práce. Je to práce, kterou nesnášim. Rozčalounit, neušpinit, nepotrhat a zase složit. Fuj. Narvi tam ten odpor a odjezd. pokud to někam smahneš, tak Tě jeden vyplasklej pytel navíc už trápit nebude.
Tušim, že tam musí bejt eště dioda, ale to bych kecal. Ty dečky mam někde zahozený v koutě asi 3. A možná přibude další :lol:
voloda
#27 Příspěvek od voloda »
riesim to iste, tak keby bol este jeden odpor na zvys, napis SZ... dik...
KamilAC
Klubové ID: 870
#28 Příspěvek od KamilAC »
Horys píše:Do pátku budu mít 2 kusy ale s dalšíma je to horší ty konektory bere stěch vadných deček.tak jak nějaký splaší tak budou dalši.
Tak na mě teda s tim taky mysli, budou teda až po novym roce? Heleď můžu se domluvit s tim jednim kámošem, a ze starejch sedáků bych mohl dodat od něj nějaký ty konektory.
milo
Klubové ID: 877
#29 Příspěvek od milo »
ma nekdo definitivni reseni toho bagu? taky sviti kontrolka bagu a hlasi mi chybu v senzoru sedacky spolujezdce. kdyz se nekde vysekam, radeji at to vystrili vsechno zbytecne, nez vubec :-/
resil se tady kontakt v konektoru, ale ten je prostrikanej durch kontoxem a nic. po vymazani se chyba objevi znovu.
milo
Klubové ID: 877
#30 Příspěvek od milo »
ted jsem podobny problem resil na jeepu grand cherokee, co ma kolega. stacilo kalibrovat senzor pres diagnostiku, vymena nebyla potrebna. co u bmw?
Miguel
Klubové ID: 1507
#31 Příspěvek od Miguel »
U BMW se nic nekalibruje, prostě se buď použije ochcávka nebo nová dečka.
brumlae34
Klubové ID: 1853
#32 Příspěvek od brumlae34 »
Odpor to nevyresi, musi se tam dat emulator presne podle cisla te krabicky do ktere se napojuje ta decka a stoji 1500,-. Jinak si myslim, ze ta decka stoji kolem 2500,- dle auta a je to docela porod se s ni prehazovat...
Martem
Klubové ID: 999
#33 Příspěvek od Martem »
Snejk
Klubové ID: 2166
#34 Příspěvek od Snejk »
Martem píše:http://www.byty.cz/xad4673732-sviti-vam-kontrolka-airbag-u-bmw-toto-je-reseni.aspx
:D to mi připomina jako oil reseter za litra (asi nejdražši kus dratu v pixle ). tak tohle je zase nejdražší odpor v pixle :D
Miguel
Klubové ID: 1507
#35 Příspěvek od Miguel »
Z pohledu člověka, kterej tomu rozumí ano, ale z pohledu lajka jsou tyto přípravky s metodou "plug and play" nezbytné pro řešení problému, kterému nerozumí. Každá věc má svojí cenu.
