Napsal: úte 28.10.2014 09:19
od laopde
Say BMW M3 is a good car, E36 Camber Plates do not think many people would deny this assertion. That it is good, how good it is in the end? To address the issue, it would have to be traced back to 1986, the beginning of the world to meet with the first-generation E30 M3, her birth was entirely directed at the Group A race car comes, because events born of opportunity M3 at the time the master-lined environment, using direct injection technology more than four jets, the use of the engine at high turn squeezing big horsepower output, combined with a solid chassis suspension power rack at Speedway Lectra opponents M3, in a praise fans the sound of the car called its altar a single show, M3 thus became fans eager to grab the structure of the object.
E30 M3 heritage of the great achievements made​​, a time when in 1993 the second generation E36 M3 grand debut. Compared with the previous generation E36 follow the footsteps of family development, and replaced with the same straight-six engine intake system is its multi-throat injection technology, but because of the use of S50B30 E36 VANOS higher displacement engine intake side causes and newly added, E30 aggressively promoted than 86 horsepower, up to 286 output values. If the horsepower figures alone should M5 E36 with the same period of comparison, then, of course, is somewhat less. But both always in ordinary 3-series or 5 series of the original foundation to build high-performance models on the same because the positioning of the vehicle is different, so that M3 has more lean than the M5, shorter body, but also aspects of body weight M5 somewhat inferior place, creating a higher M3 sports performance. This is what people say, BMW E36 Camber Plates running speed or long track, then with horsepower M5 undeniable advantages will be better; but if accelerating or driving on the short track in many detours segment, M3 in this regard more advantage.
