Jestli se lije modro - zelená nebo červená? Budu rád za radu.
Díky
Real BMW Service Intervals: Alternative BMW Maintenance Schedule
Engine Coolant Service
I recommend changing engine coolant at two-year intervals, using only factory BMW anti-freeze mixed 50-50 with distilled water (reason – BMW anti-freeze is phosphate free, phosphates cause aluminum oxidation, which blocks cylinder head coolant passages and causes head gasket failure, others may claim to be “aluminum safe” or “phosphate free” – make your choice, but I’ve used BMW anti-freeze exclusively in many cars and have never had an aluminum oxidation or head gasket problem)
čus, lije se modro zelená, kdyby si chtěl mám přímo do BMW modro zelenou.slavobmw1 píše:Zdravím, mám první BMW, a to 120d 120kw r.v. 11/2006. Asi jsem hloupý, ale nevím, jaký fridex koupit.
Díky
