Před týdnem jsme na autě měnili olej a odpojovali jsme cívky startovali bez cívek, ale to by s tím souviste nemělo ne?
Kde hledat teď problém?
Případně nějaky konakt na servis co s s tím poradí co KP motors na Tovarní 11?
Děkuji
DME active codes -
102A01 - Hot film air mass meter, signal: Electrical fault.
11C402 - Quantity control valve, activation: Short circuit to ground.
122002 - Blow-off valve, activation: Short circuit to ground.
123002 - Wastegate valve, activation: Short circuit to ground.
12B102 - Oxygen sensor heating before catalytic converter, activation: Short circuit to ground.
130002 - VANOS solenoid valve, inlet, activation: Short circuit to ground.
130202 - VANOS solenoid valve, exhaust , exhaust, activation: Short circuit to ground.
135608 - Valvetronic system: No movement identified.
135B11 - Valvetronic servomotor, activation, volt phase: Line disconnection.
138102 - Exhaust flap, activation: Short circuit to ground.
138104 - Exhaust flap, activation: Line disconnection.
164020 - Intake camshaft sensor, electric: Short circuit to B+.
164030 - Exhaust camshaft sensor, electrical: Short circuit to B+.
191002 - Tank vent valve, activation: Short circuit to ground.
1B5202 - Supply, terminal 15N_1: Short circuit to ground.
1B5302 - Supply, terminal 15N_2: Short circuit to ground.
1B5402 - Supply, terminal 15N_3: Short circuit to ground.
1C0202 - Oil pressure control valve, activation: Short circuit to ground.
1D2402 - Characteristic map thermostat, activation: Short circuit to ground.
